TwinTurbo.NET: Nissan 300ZX forum - Re: Re: If a belt is squealing is it safe to assume it needs to be
Madztt
on April 20, 2010 at 7:20 PM
Re: If a belt is squealing is it safe to assume it needs to be (n/m)
posted by Madztt
on April 20, 2010 at 07:15 PM
ASP/Unortho. UD Pulley cont. Causes Belt slip w altern. load.... search it.
pocheeyo
03:53:30 04/20/10
Marty1Mc
06:13:35 04/20/10
New belt...this is the 4th I've put on in 3 months.
pocheeyo
08:15:37 04/20/10
buy OEM underdrive belts... (n/m)
Paulym1111
10:00:54 04/20/10
Re: buy OEM underdrive belts...
pocheeyo
11:31:00 04/20/10
it's a mechanical issue, and not a problem with the belts
pocheeyo
11:34:11 04/20/10
Just fyi . i had that squealing problem and i finally
xteam300tt
12:18:12 04/20/10
Madztt
19:15:31 04/20/10
Re: Re: If a belt is squealing is it safe to assume it needs to be -
Madztt
19:20:40 04/20/10
Re: Re: Re: If a belt is squealing is it safe to assume it needs to be
jaidieray
20:42:29 04/20/10
im having the same problem at the moment
zxracer00
02:30:55 04/21/10
that had occurred to me, but the pulleys are relatively new
pocheeyo
02:48:49 04/21/10
yes each ridge. other than that i would try oem belts. also
zxracer00
03:07:08 04/21/10
well the search madztt told me to look up says to tighten to
pocheeyo
03:26:02 04/21/10
pocheeyo
03:07:09 04/21/10
